My brother has one of these things fitted and i must admit i'm not a fan.
I've just removed it from his car and tried to do the vacum test that i'd do on a 007P and it doesn't hold the vac. Is this normal??
It has 55 clicks from loose to tight, is there a scale to compare the amount of clicks to the coloured springs that come with normal forge re-circ valves? Failing that i'll stick it them both on a dead weight tester at work and make a table.
