Splashback when filling with fuel causing pump to stop
Jimlad86
233
Gloucestershire
Morning all!
This is very very strange, the last few times i have filled up, i have had big problems with the pumps clicking and stopping. I have owned the car for 2 years and never had this issue before.
Its like there is something causing it to splash back and hit the nozel.
Also, once i finally get it going without stopping, it makes a strange wooshing noise that it never made before where the fuel sounds like its bouncing off something inside.
Im going to experiement by going to a different filling station next time, but the current one i use i have never had an issue with before and they dont appear to have changed the pumps.
Has anyone ever experienced anything like this? Its getting very annoying!
jamie_
183
Cumbria
I had a similar problem on my first car could only put one or two litres in at a time before the pump would cut out. Annoying to say the least!
Turned out when I had my MOT that the fuel filler pipe running to the tank had worked its way loose from the back of the filler cap :shrug: so that might be worth checking?
Jimlad86
233
Gloucestershire
I will have a look! Not entierly sure how i get to the back of there though!
I guess it would seem loose on the inside too?
jamie_
183
Cumbria
Wouldn't know myself sorry, my first car was a corsa so could be a completly different set up.
When it happened to me, there was nothing visible wrong with the actual filler cap.
Jimlad86
233
Gloucestershire
Service and MOT are due in June so i might just have to live with it till then if nothing obvious presents itself.
Cant be arsed taking it in and have to scrounge a lift to work :p
Ol' Timer
873
Norfolk
Mine has been like it from the first time I filled it up 8 years ago. Some pumps just don't work. I usually get my fuel from the same filling station which works with my car. If a pump blows back it is sometimes worth turning the nozzle round to different angles. I don't know why yours should suddenly start playing up though.
i had the same problem last time I was filling up, I assumed it was just the crappy tesco pump! :(
when i was coming to the end of filling it, it kept clicking off, and on again. Then it felt like it was full, so i just decided to pull it out of the tank, I noticed that some petrol was sitting in the sill. not a huge amount, but more than the normal little splash you get when you pull it out.
