Speakers
wilso45
Hi guys,
have a quiery here...
i need to replace the speakers in my car doors as they are distorted...the result from being made out of crappy paper. I wondered what size the speakers are so that i can get some new ones put in?
Also i have read about adapters of some sort that need to be purchased to make the new speakers work....anyone aware of this? any info would be great! thanks.
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
the standard speakers aren't too bad if you run a decent aftermarket hu, sub and amp and use HPF settings. Mine sounds great as they only play out mid and treble so no distortion until the volume is pretty high
P.S. i don't have the speakers amped either, should last a tad longer that way
but for the road, replacing them with standard speakers is your cheapest option, however, if you want to go full whack then do your thing
Chino_UK
Team Creatine
Jul 19, 2009
1,587
Cheadle, Cheshire
I run a set of Alpine type G 17cm (about £100), powered by a GroundZero 4 chanel (4 x 85W) amp, works a treat, crystal clear all the way to max vol :)
kripteksi
You can put BOSE 17cm :) I think you with have the best sound quality.
