Spacers
Cuprajohn
The Cupra Kidd
Feb 24, 2007
332
Isle of Lewis
Im sure i read on here about peeps puttin spacers on the back wheels. now after investigation i've found i have spacers on the front, good or bad?
im rollin on lightweight 16s with 205/40s if that makes any difference
thanks
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
How thick are they mate? The fronts sit wider than the backs anyway, sot the rear spacers are more so to move the wheels into line.
I've got 5mm on my front, just to clear the calipers, will be taking that to 4mm if i can find some, as 3mm isnt enough.
Deleted member 12147
I've just fitted 10mm H&R spacer on the front. I had to put them on to get the correct offset for my wheels. Make sure they are hubcentric ones tho if they are more than 5mm.
roderrs
150
ive got 3mm spacers on mine but its a bit to close for my liking so i might get the 6mm ones ive got made to 4mm a place near me specializes in metal fabricating
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Your local backstreet engineering firm will skim 1mm off for you for beer money more than likely :)
