Spacers - Catching Solutions.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Ive recently fitted 20mm rear spacers and I get abit of rubbing. But its hardly anything really, its just catching the lip of the rear arch and no more. The car is only lowered 40mm at the rear aswell.
One solution I think mite work is to bend the lip of the arch up the way somehow because that would stop it catching.
Would it work or is there other solutions?
Thanks,
Craig.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I did think of that but i dont really want to do that. I just need to get rid of the lip really.
thats what arch rolling does - slowly bend the lip inside moving it out the way
have you seen where it's touching yet ? most of the ones i have seen are at the rear
mickeykdan
114
UK
Can the original bolts be used when adding 20mm Spacers?
I spaced my rears by 6mm. I thought 20mm sounded alot to space if I am going to keep original bolts.
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
the original bolts can be used if you have hub centric spacers that mount to the hub via another set of bolts as they have 2 sets of holes.. so you bolt the spacer to the hub, and then the wheel bolts to the spacers
martin_hill_198
160
if ur spacing te back i wud get hub spacers to spaces the stub axle out so not puttin more strain on bearing etc
OllieL
2.0 16v Cupra Sport GTi
Dec 10, 2006
1,868
Birmingham
Could you not get your spacer milled down a couple of mm?
Im thinking of doing that with mine.
Ollie
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
yeah thats what im getting done on mine for the perfect stance! lol.....well if i ever get it back
