Spacer help please
darrenh
...soon to have new shoes
Mar 30, 2005
318
Cambs
www.myspace.com
Guys/Gals
I'm looking at getting some et45 wheels, so as I understand it I'll need 10 or 15mm spacers on the back (not sure about the front yet). From hunting about on here, I see that hubcentric are a must... but past that I'm a bit clueless.
How much am I looking at needing to spend for a set for the back (plus new studs etc)? If it's loads then I may have to change my mind on the wheels.
Where do most people get them?
Thanks,
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Not cheap are they! I had no choice, i needed them to clear the brakes so on they went. I can't see why you couldn't buy wheels with the offset you want to bring them out to the arches - that's something i don't know enough about on the Leon, never mind the ibiza.
darrenh
Mar 30, 2005
318
Cambs
www.myspace.com
You changed your brakes then?
It's not filling the arches that I'm worried about, it's getting the bloody things to actually fit!! The only wheels I've found that I like that will go straight on are OZ's - and they're £900!
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Yup - porsche boxster calipers on the front :)
You could just look at it like audio ... 10% of the cost of the hardware should be put to one side for the cabling - doesn't make spacers seem like such bad value then. If it's the ONE set of wheels you actually want then the cost of making them fit is a moot point :)
darrenh
Mar 30, 2005
318
Cambs
www.myspace.com
yeah, suppose. It's been two months since I've had the money to buy them - and I still haven't found any that I'm 100% except these ones.
I can't beleive how hard the Ibiza is to find wheels for!!
darrenh
Mar 30, 2005
318
Cambs
www.myspace.com
What about THESE?
Now... the thing is - Are spacers something that you get what you pay for? I've no idea what makes a good/bad one? Bearing in mind they're £30 for 2 and the Forge ones are £30 (+ VAT) each?
Cheer guys
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
i have them on mine 20mm ones tho and ive had no problems what so ever, great value for money. Couldnt comment on the 15mm ones as they have longer wheel bolts and the 20mm ones have seperate bolts, so you bolt the spacer to the hub, then use your existing wheel bolts (including your locking bolt) and bolt your wheel to the spacer.
