South Wales Cupras Chat
Status
Not open for further replies.
Nov 2, 2004
9,335
South Wales
Well what a stupid car i have.
Had the waterpump and rest of the cambelt finished today along with an interior valet, again. lol. 57 quid. Love it.
So i took it out to log the ****er.
175g/s on about 5200rpm, so it would have hit more i reckon,
hitting 3's now and again on the CF's but nothing to worry about
WG duty goes down after nailing it shut all the way up the rev range, to the point where i was seeing about 56% at 5.5k. Like its hardly trying.
Ambient was about 14 degrees so still warm, intakes were about 30 and below consistant.
Goes like ****, but i'm not sure i'm gonna run it sunday.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Daz, with the top mounts, there isn't alot of room to remove the old stuff and refit.
I can give you a hand if you needs, and i've got the tools, so no need to buy any tools.
Nov 2, 2004
9,335
South Wales
Toasted him?
Boys, anyone know what fuses are supposed to be what amp? I think i might have replaced a blown fuse on my emmisions/boost/evap etc.. with a wrong one.
rallyslag3
60
well I think its about time i said hello on the welsh side of things! so hello!
I know Phill W. and thats about it I think.
I am Dicky V.I.P from sw-cc. and I live in Neath.
I am driving an Rreg 45 bhp corsa at the mo and it doing my ****ing head in!
never mind there is an 04 reg Ibiza FR 1.8T sitting in the paint shop.
should be out in about 2 weeks.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
And here it is:
This would be quite useful for those with ibiza's and other car's which use the same fuse positions as the ibiza! (as i very rarely have my owners manual in work)
Fuse Layout
Fuse number: Amp
1. Engine / Engine Electronics 15
2. Engine / Engine Electronics 15
3. Engine Valves 10
4. Ignition Transformer 15
5. Automatic gearbox/ reverse
light / heated jets 20
6. Automatic gearbox 5
7. Injectors / Fuel pump 15
8. Lambda sensor 10
9. "S" signal * (see footer) 5
10. Control panel / Diagnostics /
Central locking alarm electronics 5
11. Horn / Heated Seats 20
12. Right hand main beam and
pilot light. 7,5
13. Left hand main beam 7,5
14. Right hand dipped beam / right
hand lamp adjuster 7,5
15. Left hand dipped beam / left
16. Right hand parking light 5
17. Left hand parking light 5
18. ABS / TCS / ESP 5
19. Fog light / Rear fog light 15
20. Brake lights 7,5
21. Hazard lights 15
22. Indicators 7,5
23. Windscreen washer and
pump / rear windscreen washer 15
24. Head lamp washer 20
25. Heated rear window 20
26. Control panel lighting /Control
panel display / Electric mirrors/
Dashboard lighting 5
27. Inside, boot lighting / Alarm
Siren 7,5
28. Lighter 10
29. Radio / CD 15
30. Heater 25
31. Number plate light 5
32. Engines central locking 30
Fuses above relay switchboard:
33. Electronic front windows 30
34. Sunroof 15
35. Electric font and / or rear
windows 20
36. Canvas Roof 20
37.Power socket in luggage
compartment 15
Fuse Box in the engine compartment on the battery:
Radiator Fan, 1st gear 30
ABS engine relay 30
ABS main relay 30
Metal fuses (These fuses should only be changed at a SEAT Official Service Centre)
Alternator 150
Onboard network 110
Radiator fan, 2nd, 3rd level 40
Engine distribution system 50
Glow plugs 50
Fuse colour code:
Beige 5amp
Brown 7.5amp
Red 10amp
Blue 15amp
Yellow 20amp
White 25amp
Green 30amp
Fuse 9 on the main strip:
The "S" signal is a system which incorporates steering wheel lock and ignition. Once the ignition is switched off and without removing the key from the ignition, this function allows you to switch on some of the electrical equipment such as the car radio, the courtesy light, etc.
This function is deactivated once the key is removed from the ignition
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
i stayed with a civic sport R lol
i was tootling along doing 50 in a 50 zone, minding my own business when he over took me :lol: so down into 2nd, matched him but he was already in front. couldnt floor 3rd without going up his arse, so jammed it into 5th and pushed him to silly speeds until i realised i didn't want to go to prison and slowed back down to 50.
he took a fecking ice age to get over a tonne mind
hi rallyslag3
Nov 2, 2004
9,335
South Wales
I have no idea wtf is goin on with my car and why its running lean all of a sudden.
If the maf was reading low i'd replace it or if i had a boost leak, but i have no idea.
Anyone know if the N112 would have anything to do with it running lean?
acidstrato
Dec 9, 2004
5,942
the n112 is all about managing boost on start up aint it so not sure if it would. ecu would adapt fuelling to match airflow so i don't see why it would.
injector issues maybe? or lambda sensors
Nov 2, 2004
9,335
South Wales
I thought lambdas dont measure a/f as theyre narrowband and as the maf is readin well it should be ok.
My feelings are toward the fuelling side now.
Stupid car.
StanTheMan
afr's of 13+ on a stressed turbo car is just asking for trouble. Peak power is made 12-12.5 on a petrol turbo. Most are mapped to run mid 11's for safety.
Its pointless guessing whats wrong until you sort the ****ing thing out!
My wb is showing mid-high 11's on boost, occasionally dipping into the low 12's. The rosstech calc seems to be roughly +0.5afr above my wb
Nov 2, 2004
9,335
South Wales
As jonzy said, 13+ is asking for trouble, my problem is i've seen perfect A/F of mid to low 12's on WOT since fitting the k03s, only things that have changed are... plugs, melted N112 and blown fuse resulting in limp mode and me soldering in a resistor.
So could it be the spark plugs?
(yes i know its ****ed, but its been ****ed before and the a/f was fine)
Status
