Hi
I have bought some cupra wishbone bushes to replace the ones on my PD130. As they are solid, compared to the PD130, they should be better, and also get rid of the clonking suspension i have
However i have a technical question, once the bush is in the mount, how do you get the bush inside the wishbone? For anyone who has done this job, they will know what i mean, the wishbone has a hexagonal shaped end, like a bolt, and the bush has a hexagonal gap, like a socket. It is a very tight fit.
Is there a technique or tool you can use in order to get the parts together properly?
