Some Leon FR TDi Questions..
terrymcg
67
Hi guys,
Looking at part exing my 06 R32 DSG for something a bit more economical. So been looking at FR TDi's. By the way if anyone wants a swap get in touch!
I just have a coupleof questions:
1. Do they all come with ant-dazzle rear view mirrors as standard?
2. What options apart from Bluetooth get you the larger display,like the golf one, in the dash cluster. Is it purely an option at build?
Many thanks in advance guys,
Terry
Rob100
Hi Terry
On the facelift model, the auto dimming mirror comes as part of the convienience pack with rear parking sensors, auto lights and wipers.
I think all the new FR's come with the larger display now due to the gear change indicator on the CR engine. But may be wrong...If so you'll need the bluetooth, which you should get anyway!
Rob
LeonCR
2,389
Hi Terry
Rob
last time i checked everything from SE up had the larger display
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
God, if I could get insured on an R32 I'd be straight there for the swap mate :D
Only the Ecomotive, FR and Cupra come with larger MFD unless Bluetooth is specified :)
Danny.
jezyg
2,324
22
Derby
Hi guys,
Terry
Depends on pref FL or FL.
1. Anti dazzle mirror in both was and is part of an add on pack on an FL it is in the £220 convinence pack.
2. On pre FL only came with bluetooth or the Sat nav option. As said on FL models is standard with either bluetooth/Sat Nav, Euro V engines or ecomotive. The FR gets it as standard as has the gearchange indicator.
tissot
152
york
on the FL the blue tooth caller id comes up on the sterio and when you change settins on the air con that shows as well
