MarkJ
Ibiza GTi
Mar 26, 2007
437
Chesterfield
Hi, seem to have a few strange noises happening on my car which are just a bit annoying. I have a standard Mk2 GTi 8v.
1. When i accelerate really hard i get a knocking noise under the car, sounds like middle if car, just behind front seats. Thought it might be exhaust but that seems ok.
2. Also get a scraping type of noise coming from n/s/f wheel when turning right, at low and high speeds, still got standard 15" wheels on so shouldn't be catching anywhere.
3. And finally, getting i kind of clicky noise whenever i accelerate, even just touching accelerator then stops when i take my foot off pedal.
Any ideas :confused: Would really appreciate any help.
MarkJ
1. I have a banging noise that sounds like its from under the car.. Put you hand on the roof in your car in the middle and see if it stops. Mine does I think its the Ariel cable or something hitting the roof from under the roof lining.
Or on my old car - were the handbrake is under the casing the cable sometimes knocks on the floor so it could be that. That sounded like the exhaust.
2. Maybe a wheel bearing???
and 3. I don't have a clue.
Hope that helps a little.
x
1 - Check the positioning of the centre silencer. If this is wrong it will move under load and bang up against the braces that the heatsheld are held on with.
2 - Check the protective shield on the discs and the hoses. Also check the pads.
3 - Er.. no idea.. Does it sound engine based?
Thanks guys, ill check them out later. Yes definately sounds like its coming from the engine somewhere, can't hear it when ticking over just when pressing accelerator.
mine did too about the pedalbox,and i had exhaust rattle when giving it some,
check your engine mounts as well i rekon.
Pedal box would only be cluctch based as throttle isnt part of the main pedal box. Check it tho. They do go if youv got a heavy pedal. Do a clutch as well and all problems will be sorted if the pedal box is your problem.
Exhust is a common problem with noises, especially heat shields and the bracket that holds it up, get a rubber to sit between and noise will be reduced.
Hope this helps
