Remember that on the rear you can go up to 20mm wider, and the front roughly 10mm (I wouldn't go this as you can't get them hub-centric and you get alot of wobble). 6mm on the front you can fit without wobble as the hub sticks out still and your wheel can sit on it. Unless you go 15mm which you can get hub-centric.
How does it sit at the back or have you not tried?
Try them on the front yeah. I don't think 5mm will be big enough, might be but on full lock I'm not convinced!!
If you are going to go for them go to venom and you get them for sub £20 FK spacers as well!
really like the look of these wheels ..... but a think comp mo's are more my styleeee lol
Quite like the look of those... Just need to get them on the car...
Daz
Really need side on pictures to see what they are like. Basically measure how much room there is between the wheel and arch and get some spacers to fill the gap!
You will notice rubbing more when driving, but you should be able to put your hand behind on full lock and see how much room there is.
Remember you will need to have longer bolts for the spacers Even though they are only 5mm.
No bother about the help!
Pictures?
