andrewcoley
Hi all
I've got a 54 plate Ibiza Cupra TDI; completely standard.
It seems to me to be slightly less responsive the last couple of weeks, on initial throttle movement in particular, turbo maybe coming in slightly later. Still goes very well at higher RPM but sometimes having to come down a gear where before the turbo would have done the work.
Also noticed it's lost a couple of MPG, on a tank of mixed motorway/A Aroads it doing 44/45 ish, where before it was 47ish usually. No change in driving style.
I've read lots of EGR valve threads, as well as various sensor replacements, split hoses etc but am at a bit of a loss as to where to start, as the problem isn't serios enough to point to anything definate; still fast, no weird smoke, not awful MPG, not going into safe mode. I did wonder if it was just me being very used to the car (maybe just in head, doesn't 'feel' quick any more) or the warm weather taking the edge off it?
No VAG com but could get basic fault codes read if necessary if this wil point to a quick solution rather than take apart and clean job? Sorry I know this query is super repeated, have searched forum but nothing definitive. If there is an FAQ / order of checks for this fault please point me in right direction.
Thanks, Andrew
Thanks, Andrew
