Skimmed head - what increase do you get
james_mk
Mk bandit
May 14, 2004
241
milton keynes/coventry
As im having the head gasket , cambelt etc done...im also having the head skimmed...the garage that are doing said that they could skim it by 4mm as it will increase the combusion ratio or something like that.... any ideas what gains id get
mines a 2L8v
Cupra_power
torque ain't cheap
Nov 1, 2004
517
the burbs...
Improved volumetric efficency, improved mid range torque depending on the increase in compression ratio you might have to start using high octane fuel.. 98 RON or 99 RON
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
4 mm you mean 4 thou? dont bother its no better than std and if you ever have the ehad gasket go youll have less room for repairs.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
james_mk said:
yeah i know there wil be less room if the head goes again..but its not likely.
I run my car on BP's super unleaded anyway..whichever RON it is...
mk2 heads can go at any time, mine went twice in 8k. and octane rating means diddley.
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
cordobabrendy said:
...octane rating means diddley...
Pardon? If compression ration is increased significantly, then you'd need to run higher octane fuel to reduce the tendency towards pre-ignition (which seems to be fashionably referred to as "detonation"). A skim on 4mm would increase compression ration significantly. A skim of 4 thou wouldn't.
If the head gasket has gone, then the head may require a skim if it's warped a bit, but it's not always necessary. If all the valve gear is getting stripped out for the head to be skimmed, it's probably worth having it crack tested too... (it's also a convenient excuse to have the head ported while you're at it...)
james_mk
Mk bandit
May 14, 2004
241
what are you on about diesel dont confuse me!! so your saying im going to need to use higher octane fuel , right? What sort of work is involved to have the head ported? a lot more?
hopkinsgm
May 25, 2001
2,030
I think Cupra_power may have been kidding...
If you know the swept volume (easy enough - divide engine capacity by no. of cylinders, so for a 4 cyl VAG 2.0 it's 1984cc/4 = 496cc) and the original compression ratio, you can work out the size of the combustion chamber before the skim. Compression ratio is (swept volume + combustion volume)/combustion volume. If you then measure the size of the combustion chamber after the head has been skimmed and rebuilt, then you can work out the new compression ratio as swept volume won't change.
(edit) to answer the question about octane, no, you probably won't need to change from whatever fuel you're using at the moment so long as the compression ratio doesn't change from say 10:1 to 12:1. Check with your engine man about how much is going to be skimmed off. 4mm sounds ridiculous (was half asleep when I posted earlier...)
Cupra_power
torque ain't cheap
Nov 1, 2004
517
the burbs...
Pulling your leg , if you skim enough off the head, the compression ratio will be high enough to ignite the fuel without the spark plug and Viola you have a TDI:D
ibiza_95
1.8T MK2 Conversion
it does do a bit ive heard, but i had mine done when my head gaset went and i cant honestly say its noticeable, its only 20 pounds to have it skimmed anyway so if your gaskets gone just get it done anyway for the sake of it.
if its not gone... 20 skim plus 20 gasket and bolts, still only 40 quid, you never know
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Consider also the implecations of cam timing and relative PDC position when its been skimmed. 4mm sounds waaayyy tooooo much, and I would also check for valve to piston clearance to see what was actually available.
Was it 4mm? or 0.4mm?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
slight misunderstanding here G, I meant that on an 8v otherwise std, changing ron wont make the car noticeably faster, i had my head skimmed the first time it went and it was exactly the same as before hand, ie same speed at road markers etc.
james_mk
Mk bandit
May 14, 2004
241
Im gona have to check avec mon mechanic, im sure he said its 2mm ml for a normal skim on a h/g but he could do it 4mm.. ibiza95..dunno where you got this 40quid from?? the whole jobs costing me £375....thats for a new head gasket,skim,and cambelt.
hopkinsgm
May 25, 2001
2,030
A skim on its' own will probably cost about £20. Cam belt isn't expensive, and a set of gaskets won't cost the earth either. Most of the £375 you've been quoted (or estimated? That's always worth clarifying...) will be labour charges. Labour ain't cheap these days. And by time you've removed the head, stripped the valve gear, re-assembled the whole lot, that's quite a few hours work.
