Ok, for those who have chnage their LCAs/wishbones, I have a question.
Is the front bush part a tight squeeze? I just want to be 100% sure of my memory of when I fitted mine (and yes, I'm prepared for the jokes about the question)
The front bush is tight, NOT AS TIGHT AS THE REAR!
Actually no, I'd say it's just a bit more awkward to get it in the rear, especially when you've done the front first.
What were we talking about again?
OK - so being dead serious now, it is a tight fit. I found I had to almost force it in, which I put down to the new bushes, but it definitely took some effort and a bit of manipulation. It was hard to get out as well, which suggests that even when the bushes are worn, it's still very tight.
It makes sense though - even though the rear bolt stops most of any back and forth movement there's ever likely to be, you don't want any slop in the front either.
