Silly lower control arm question
MoToJoJo
823
653
Northants
Ok, for those who have chnage their LCAs/wishbones, I have a question.
Is the front bush part a tight squeeze? I just want to be 100% sure of my memory of when I fitted mine (and yes, I'm prepared for the jokes about the question)
iammooks
1,784
1,172
The front bush is tight, NOT AS TIGHT AS THE REAR!
Actually no, I'd say it's just a bit more awkward to get it in the rear, especially when you've done the front first.
What were we talking about again?
OK - so being dead serious now, it is a tight fit. I found I had to almost force it in, which I put down to the new bushes, but it definitely took some effort and a bit of manipulation. It was hard to get out as well, which suggests that even when the bushes are worn, it's still very tight.
It makes sense though - even though the rear bolt stops most of any back and forth movement there's ever likely to be, you don't want any slop in the front either.
MoToJoJo
823
653
Northants
Yup, I laughed 🤣
Cool, I thought I remembered it being snug enough that once in it happily held itself in place without a bolt.
Cheers 👍
Alexis27
2,144
478
Manchester
Isn't half the battle getting it off without snapping? Replacing the bush is a bit moot if it snaps when you take it off 😀
smutts
373
188
Oooooooh! a captive bolt on the loose in the subframe, the horror, the horror.🤢
iammooks
1,784
1,172
Don't get me started - when I undid mine, the garage before had done it so tight that when it backed off, it probably set off the earthquake sensors. I just stopped what I was doing, packed up my tools and went indoors.
When I finally summoned up the courage to go back out and deal with it, it turned out it was actually OK. That's what led to my car mantra - 'expect the worst'.
Reactions: Rich.T
