Sidelight Bulb Change?
naz90uk
15
Hi, i am struggling to locate the sidelight from the back of the headlight. Does anyone have any guides on how to replace it with pictures in a Seat Leon 2012 mk2 1p. So frustrating
Jfox
395
If its any help its the very far light. the most awkward one to change.
I think there is a rubber cover you need to take off.
Should be simple if u have a poke around.
Y80LEE
Y80LEE
Sep 1, 2016
15
Hull
Hi your side light will be located towards the outer of the head lamp below your day time running bulb. You will need to remove the rubber cover off back of head lamp by pulling it off. You can get to this easily by under the bonnet. The side light fixture will just pull out its kind of on Spring taps and it will be a 501 capless bulb.
Hopefully this will help you naz90uk sorry couldn't show you a photo need to be full member to do so.
naz90uk
15
Thanks for the replies guys. seems difficult than first thought. will have to give it a go. if not will show pictures. much appreciated for your help!
