Should i have a ESP lights?
joey_b
the flap that goes over the top of the steering collum lifts up ant theres 2 philips screws 1 eaither side then the clocks pull out, the smd led's are soldered to the actual circuit board tho.
CHRIS87
75
as long as i can get to circuit board which it is soldered to i can check weather it is getting a signal to switch on and weather it is working properly!
