Right. finally managed to fit my short shift today.
easy enough to fit with the right tools. .
I'm finding that i struggle to get into first gear. I just won't go in sometimes!!! esp after just starting up. A few times i've had to go into another gear first then into first gear. There is a similer problem when changing down from 2nd to 1st gear (at junctions etc.)
It's not every time but it generslly happens when you least expect it or when you think the problem has eased off.
Up and down movements of the gear knob also feel very tight and juddery (side to side are as normal).
any ideas on what the problem might be or how to smooth it out.
other than that it feels tight but good. albeit a bit notchy, but i was expecting that. It will take a litle time to get used to.
any ideas???
any ideas???
