shift solenoid valve code
K3mist
Simples!
Dec 11, 2008
96
East Sussex & The Shire
Has anyone come across an error code that points to the shift solenoid valve?
My Leon TDI went into the garage last week to fix the coolant temp sensor, after the Engine Management light came on.
Today on the way to work it pops back on and the garage has said that the error code is now pointing at the shift solenoid valve.
The garage have said this is very odd as it usually refers to an automatic gearbox which mine is not.
Has anyone come across this problem before?
The garage have told me that they have cleared the code and the light refuses to come back on. I think they are scratching their heads a little.
Any ideas?? :confused::confused:
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
That would be for an automatic gearbox (difficult to say without the exact code), maybe something is coded wrong?
K3mist
Simples!
Dec 11, 2008
96
The code the garage gave me is P0268.
Looking on the code sticky it relates to this: Cyl.3 Injector Circuit High Input/Short to B+
Is this correct?
Why didn't the garages machine come up with the same explanation?
Sorry if these are obvious questions, this is way over my head! :D
K3mist
Simples!
Dec 11, 2008
96
I think that may be the case mate. :confused:
The light came back on the other day and the same garage has just told me
that the code it has thrown up is P0674, which I can't find on the VAG code list!
Anyone know of a decent VAG specialist in the Milton Keynes area?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
googled said:
Fault Code P0674 Cylinder 4 - Glow Plug, Circuit
Either a bad glow plug, or a bad connection between the glow plug and the glow plug harness.
just googled that if it helps ?
