In the end a garage got the Forge tip on for me. It seemed to pick up a little better and I also saw a small increase in boost on my gauge so I was quite chuffed but 1 week after fitting, the engine light on the dash came on. I've just run VAG-COM on it and it says:
'Secondary Air Injection System: Incorrect Flow Detected---Intermittent'
I'm not saying it is the Forge TIP but wondered if the increased air flow had anything to do with it. I've swapped the GFB dump valve back to the Bosch one incase it was a combination of that and the TIP. I've also cleared the faults with VAG-COM and disconnected the negative battery terminal for 20 mins. I guess I'll have to just wait to see if it happens again.
