Seat leon tdi 150 fr+ brakes size
Bogwoppit
1,085
Lincs
The Front brakes are 288mm x 25mm Vented Discs, the Rear brakes are 232mm x 9mm Solid Discs. The FR TDI and FR+ TDI have the same brakes.
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
can someone clarify for me the standard size of a mk1 leon cupra 180bhp (54 plate i.e. facelift) disks.
i've looked on so many websites that say theyre the same product as the LCR and others that say completely random sizes. ta
MDS
Marco
Dec 10, 2006
936
I am just saying this as an assumption, but theyre probably the 312mm like on the TT/S3.
Dont think they featured the big bad brembos like the LCR.
But then again , cant be 100% positive...
MrJohnnyB
358
Sudbury, Suffolk
That's right. 312mm Fronts. I believe that all leons were fitted with the same rears...
MrJohnnyB
358
Sudbury, Suffolk
The Discs on LCRS are 323mm? (or am i being retarded?) and the bonus comes mainly from different calipers/carriers. The Brembos are better because they protrude slightly further from the disc and thus can get more force or some such crap, I had it explained to me at some point but i forgot shortly after.
strugers1
up to a certain plate on cupras come with 312 after a certain date they went to 288 same as others
bruceR
2,558
647
Monifieth, Dundee
The 312mm set-up from TT/GTI/Cupra would fit, you need carriers, discs and pads. The bonus is you can keep your calipers as they fit straight on.
As for the FR and FR+:
FR is the new name for the MK1 Cupra - standing for Formula Racing
FR+ was donned with LCR front & rear bumpers and given a set of 17" LCR alloys.
This should answers your Q's
very useful thanks!
why on earth did they not put 312 brakes on the FR? Car is no smaller or lighter or powerful than the Cupra?!
just been to look at one I saw last night and its gone already :(
Sprogpole
360
Leicester
What is the fascination with everybody wanting bigger brakes at the moment?
Yes they look cool, and the 4pots obviously offer more stopping power.
But with the single pot 288/312mm Calliper, it will make no difference unless you’re taking it on a track.
If you have the 288mm setup, you’ll get a much more improvement from getting good pads (1144 /DS2500 or better) + the 288 disc will cost less.
A smaller disc will be lighter and will give better handling as the un-sprung weight is less.
4/4 dirty dervs
243
kent
i fitted 312s to my pd130 and feeled a vast improvement actually suprised me.. but my 288s i replaced were warped so werent in the best nik anyways so probably not the best person to compare the difference .
Sent from my LG-D802 using Tapatalk
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
would the bigger calipers fit on too? Looking at a complete set rather than just carriers and discs etc
The calipers and pads are the same on the 288mm and 312mm set-up, just the carriers which hold the caliper further out from the hub and discs which are obviously bigger.
I agree in terms of stopping power, doesn't provide much difference going from 288mm to 312mm but they do look a little nicer behind big wheels and if you find a second hand setup they can be had from £50.
Reactions: Sprogpole
RedPanther1.8t
10
I've just gone from 2003 petrol Cupra to a 2005 FR 150PD. The rear discs on this car are quite rusty and need to be replaced. Is it possible to upgrade the rear discs from 232mm you get as stock on FR to the 256mm from a mk1 audi TT? Will it be an identical process as upgrading the front with same original rear callipers of the FR mounted onto the rear calliper holders from 256mm Audi TT?
