I could use some help here gathering ideas on what could be going on. 2 months ago I had the check engine light come on(orange) and went to get it checked at a seat dealership/shop. They said that it was coolant pump b being defective and in need of replacing. They then did this after much delay and the day I was suppose to pick up the car I was told it wasn't the pump but ECU as the fault was still there after they have changed the pump.
So I get the car back as I was told I could drive with this fault until we could schedule a new appointment. The car finally goes to the shop again, they change the ECU and when I pick it up I get the check engine light again immediately. I then scan the vehicle with my own OBDeleven and get a ton of errors, including cooling pump B, but also transmission errors, some heat exchanger thing(don't know what its called in English), infotainment errors, and drive motor errors(not sure of the name, but I think its the electric motor but not sure).
I've now been told that they cannot figure out the faults as they have checked all parts that have error codes for them and the relevant wiring and that they have contacted Seat technical division for further advice. I don't have much confidence anymore that things will get sorted which is why I hope that maybe some of you could have an idea of what to look for.
