Seat ibiza tdi 110 sport problem
Ro55
Hi all, got a problem with my Ibiza. When ignition is on all dashboard lights light up as normal and all die away bar the ABS and Traction control. When the engine is turned on, the traction control light dies away a few seconds after. The abs light dies away when the vehicle is in motion. I still have ABS and traction control working properly though. Can anyone offer any help?
cr33p
diesel powah!
Sep 11, 2006
141
Slovenia
Happened to mine last week. It turns out there was a loose cable on the alternator. Have it checked.
BTW: you can check it yourself. Measure the voltage on the battery. When the car is not running, it should be between 12V and 13V. With the car running it should be around 14.2V -14.4V. If it's not, then your alternator is not charging or your battery is dying.
