Seat Ibiza ST Toca Undertray - Not sure which Part
RUM4MO
8,088
1,108
South Scotland
Try using ifinterface.com maybe a bit clumsy to get into easier using ipad etc I've found.
I've had a look and it will only be the front part that was fitted to your car if it has a petrol engine, the base part number is 6R0 825 237 but you need to work out which version it is, ie "A" or "D" or "E" . You will also need to buy new bolts which are N 907 750 01 and maybe some speed nuts which are N 103 271 02. I've forgotten how many fixing bolts you need maybe 6 or 7.
I would expect a lot more from any SEAT dealership part's department, give them your car's reg number and they should be able to tie down exactly all/any parts you would ever need!
Edit:- yes I see that you have the 1.4 16V petrol engine.
