Seat belt tensioner bit stuck help please
ibiza_95
1.8T MK2 Conversion
Its ok i sorted it :D
ill post up here just incase anyone searches for the same thing :D
Remove left side of the mechanism (plastic cover) looking at it from what you would expect to be the front ;)
OK... The yellow plastic piece is a stopper which engages with the big black wheel to lock it... to free the black wheel, press the yellow piece down and pull at the belt until it is free. The system will only work when the unit is at 90^0 to the floor BTW once this is freed, youre done. :)
Very interestingly brilliant mechanism i thought :D
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
safer still make sure they are in the correct position and they will pull out anyway :)
as long as it all clips back together ok should be fine though
