SD Cards for Seat media System E
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
I tried a Play.com own brand SD card in the loan Exeo I had and that worked, but just wondered if any should be avoided. Guess I'll stick with what I know, cheers :)
RobM
Sep 27, 2006
4,982
Southampton
Well I ended up buying a couple of these: http://www.play.com/Electronics/Ele...d-16GB-SDHC-Class-10-Memory-Card/Product.html
All loaded up and ready for Monday when the car gets delivered :D
I went for this option over and above the iPod as, like others have said, it's just too limited. I have bought an iPod dock extension cable and an adapter that allows it to charge my iPhone, so that's my backup plan should I need it.
whaleyp
Which 32Gig FAT format should I use (default allocation size?)
I spent an age selecting folders from my MP3 collection, copied them to the 'out of the box' 32Gig SD card (~£20 off ebay - brand new!!).
When I plugged it in to the car it said it was corrupt :censored:
I wonder if anybody know what block size/allocation size to use for the FAT32 format on a 32Gig card? :think:
Here's the compatibility chart (it's at the end) (had to change the '/' to '\' as I cannot post URL's as a noob)
www seat at\countries\at\files\seat_exeo_multimedia_2011.pdf
Mine is 'Class 6'.
en wikipedia org\wiki\Secure_Digital
So is faster than the 'class 4' mentioned in the specs.
I'm assuming I should therefore be OK?
RobM
Sep 27, 2006
4,982
Southampton
£20 for a 32GB SD card is way too cheap and eBay is way too dangerous when it comes to fake SD cards. Put those two thoughts together and I think Dark Andrew has it spot on.
It's also worth noting that it's not particularly difficult to make an SD card report a much larger capacity than it actually is, so when you insert it into your computer, everything looks fine and dandy.
whaleyp
Ouch
Well.... it looks like you were correct.
The memory card is a fake - the seller has vanished off ebay and removed the item. Paypal will (hopefully) protect me and give me a refund but it's not the end of the world if not.
Thanks for the pointer - I'll buy the play.com ones listed above and learn my lesson.
RobM
Sep 27, 2006
4,982
Southampton
I'm sure it wont make you feel any better, but you're far from the first and certainly not the last person to be scammed with these :(
Fingers crossed for a quick resolution for you.
