S3 Intercooler successfully installed on my Cupra
Romm
I finally managed to install a S3 intercooler on my Cupra the other day.
Installation was an absolute nightmare and took me about 5 hours to complete freezing my butt off in the driveway... :blink:
But the results are definitely worth it! :D
It feels like the engine runs more smoothly through the gears now.
My buttdyno is shoving a small increase of torque in the entire rpm range. [B)]
Pictures of the mounting procedure can be found here:
http://picasaweb.google.com/rasmus.romm/S3IntercoolerMounting
Xe
Nice, thanks for sharing. Good collection of photos you have there. Quick question is it easy to get the front bumper off? Could you explain how and do you have photos?
Cheers :)
SEATcarsdirect.co.uk
Well done
cant wait to hear what it comes up with on a RR
Irfan
Romm
So the OEM S3 pipes work?
Will be good to see and compare r/r results with stock and S3 intercooler.
Exactly! The OEM S3 pipes fits perfect...
Cupra pipes are held in place by a wierd spring clip. The S3 pipes on the other hand are held in place by hose clamps not utilizing the spring clips.
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
very interesting. I would have thought they S3 and cupra would have used the same intercooler seeing as the cupra has been getting 260ish on the dynos.
Al
7,331
9
S3's are also making more than the quoted power from Audi ;)
Romm
so has anyone got the item codes for all the parts i need to install the S3 intercooler
cheers
You'll need the following part numbers:
S3 Intercooler > 1K0 145 803 P
S3 Left Pressure hose > 1K0 145 834 AA
S3 Right Connection hose > 1K0 145 832 L
You'll also need ten 16mm x M6 bolts (preferrably with umbraco heads) with washers in order to install the S3 intercooler... that's it!
This thread at Golf5gti.com was my main source of inspiration, before installing the S3 intercooler...
http://www.golf5gti.com/viewtopic.php?t=3023&postdays=0&postorder=asc&start=100
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
sorry bud i cant get the link to work! i will try again later. did you notice a differance with the S3 intercooler fitted
how much all in did it cost you for the parts mate
thanks for your help
Romm
Sorry mate I was a little too fast copying the link from another thread...
Link should be fixed now... :)
There's a noticable difference in the midrange the car pulls a lot harder.
Total cost was around £240 for the parts alone. :)
