Hi guys...
I was giving it some beans getting onto the A14 on tuesday night, and the car seemed to be hesitant at about 4000rpm, and then the EML came on, and started blinking intermittantly.
The car went into limp mode (i presume), and was vibrating badly while under any throttle. When i got home about 2 mins later, the car was idling rough, and still showing the EML.
I picked up a coilpack the next day, as I presumed thats what it would be having read the sticky at the top, and tried pulling off the loom clips to find the cylinder not firing. Much to my dismay, the idle got worse when i pulled the coilpack plug off each cylinder! Not a blown coilpack then...
Today i picked up a new Bosch MAF sensor, tried fitting that, and the fault still remains!
Ive had a quick poke about the engine bay, and cant find any loose or split hoses, breathers or boost leaks. I havent pulled the plugs yet, but i changed them about 20k ago, so i cant imagine its them.
So, does any one else have any further ideas?
Thanks in advance,
Dan
Thanks in advance,
Dan
