Routing CD changer cable
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
Hi all.
Now that my CD changer is fitted and working I wonder if I've done the right thing.
I've run the cable from the head unit to the boot across the passenger footwell (behind the glovebox) and down under the left side cabin trim (floor level).
Also have fixed the ground/earth wire in the boot on the left side near the wheel arch.
Sound seems good but will it deteriorate?
Any comments?
Thanks, Guy.
gazjones
if you have run it under the trim it wil be fine the outer casing is pretty tough
gazjones
if you have used the ligh earthing piont on the rear wheel arch that will be fine
maxcars1
735
Gaz does the glove box lead come with and earth lead requiring connection - sorry for hijack
gazjones
yes it does i earthed in to the frame of the dash next to the air vent with a spire clip ill get a pic for you
maxcars1
735
Quality as I have a cd changer sat in my house now:whistle: Need to speak with Vinny's Discounts tomoz for availability of lead:D
gazjones
lol anbd ask him where my interior bits are! want help fitting it! then you can see my install lol
gazjones
cool ok glad i got it out my dads leon! saved me 35 quid that i can use for boost gauge upgrade
