Rounded Sump plug... Well almost.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Right, got under the car today to undo the sumpplug to give her a oil change and it seems that the person before has attempted and failed or not renewed the plug as it looks pretty sheerd off... and it it also very tight... whats the best thing i can do to get it out ive doesed it in WD40.. but what if that fails?? am i looking at a new sump? Help :cry:
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
a friend of mine welded a nut onto the stub i left when i rounded it, came off a peach afterwards
Riddick_m3
339
Sudbury, Suffolk
try to get a multi point socket to grab on it not a normal hex type might be lucky like that failing that try to get some grips/stilsons on the head of the bolt tap bolt head before trying to shock the thread, failing that mate its going to be grief without removing the sump, try heating it alittle bit to with a blow gun, hopefully the muti spline socket will do the job though,
good luck
andyj
There's no F in Quality..
what style socket are you using? one with 12 points in it? or a proper 6-sided one?
I can't see that it's rounded so much that a proper 6-sided socket won't be able to get a grip on it.....
Other option is to use a 12 pointed socket that's 1mm smaller, and hammer it onto the sump plug, and undo it that way.
orca
412
N Kent
www.bdmlr.org.uk
mole grips. But tighten it a littel first. It is always eaier to break seal on a tight bolt if you just tighten it a tiny bit. most manufacturers recommend a new sump bung at each oil change. A lot of this problem comes because people do not even change the washer everytime let alone the bung it'self
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ive been ripped off by the sounds of it!!!! [:@] :censored: i payed 9.13 for the plug and washer from the stealership!:censored:
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
just for info
the abf 16v mk2 engine uses an m26 sump plug an the 8v an m10
m26 is like rocking horse poo to find, i had to go to a vw dealership 10 mile away to get one
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Saul said:
just for info
And how much did you get charged?
