Brayn Jun 26, 2024 3 0 Jun 26, 2024 #1 hi every on i have a problem with my 1.8 sti it runs rough an idlle poor do any one have a selution for this problem
R3k1355 Active Member Oct 30, 2014 1,819 258 Yorkshire Jun 27, 2024 #2 Could be anything. You need to read the ECU fault codes first. Upvote 0 Downvote
Brayn Jun 26, 2024 3 0 Jun 27, 2024 #3 R3k1355 said: Could be anything. You need to read the ECU fault codes first. Click to expand... thats the problem there are no error codes Upvote 0 Downvote
Frostensen Active Member Aug 10, 2019 107 7 Jul 8, 2024 #4 Loose timing chain, loose alternator belt, bad coil packs, possible vacuum leak somewhere. Upvote 0 Downvote
