Rookie wheel question
Damo H
4,707
2,816
Car Length In Front
Carbonara
81
21
SRGTD has given above a very comprehensive account above of all the factors to think about when looking at an alternative set of wheels.
BUT I am still in limbo with a choice of winter wheels for my forthcoming Carbon Edition.
It comes with 19s but I really want to go to 18s (painted not diamond cut...winter use!)
Now Carbonara has already kindly pointed out that Team Dynamics pro race 18X8,et 40/45 will fit,the issue being the INSIDE clearance to go over the larger Brembo brakes.
Fine,but everyone likes a bargain and it's possible to buy a set of Wolfrace pro lite,same size and offset for a lot cheaper,only about £400 a set.
Both of these types of wheels are a similar design and are a semi light weight wheel,so you might assume that the inside clearance would be much the same,but I've tried two national alloy wheel companies so far...and they haven't a clue.
So the other important dimension,in some cases, is inside clearance diameter,which nobody states!!!
It's also about the internal profile of the wheel too, and specifically where the narrowest point is - and also where the weights can be positioned.
I got the internal measures for mine from Rimstock verbally, but have since thrown the scrap of paper once I knew my wheels fitted. PM me for contact details and another way to reduce pricing. I've only bought my 3 sets of ProRaces direct. They also told me that the matte black finish was harder wearing than the gloss black.
Damo H
4,707
2,816
Car Length In Front
3 sets?
Carbonara
81
21
Yeah, 4 sets now I come to think of it, but still got 3 of them. Fabia has 2 sets, but I've used the others on several cars. Made it awkward fitting the Cupra into the garage. Doing my own winter/summer swaps is like moving house! :-D
Oldbutswift
284
91
You have PM,thanks,
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Out of curiosity, why are you not going 225/40 R18s (as the standard FR with 18s have ) and instead going 235/40 R18s? Or are the BBS you are eyeing only can accomodate 235s? Tyres tend to be cheaper @ 225/40s, plus, I'm not sure on a FR you will need the extra width of 235s
Oldbutswift
284
91
Sorry,my comments about winter tyres for Cupras are mixed into this thread.
225/40 will be fine for FRs.
The Cupra has 235 tyres standard so I would tend to stay with this width.
Carbonara
81
21
I had wondered this too when I found out the 225 was the default 18" size. I just did the calculation for mine based on the 235s fitted when delivered. Some advantage to narrower tyres in winter for aquaplaning and snow, but 235/40 is the nearest down conversion from 19" PP Cupras. To be honest, with 8" wide wheels, I wouldn't want to go much narrower anyway.
Damo H
4,707
2,816
Car Length In Front
I've always had the understanding that the narrower the tyre the better for winter. However when I read a tyre article a while back, one of the big tyre manufacturers (Continental I think) has said that in their testing, the bigger contact patch is still better :blink:
Carbonara
81
21
If you think about it, it's just too much water that spoils things in winter, breaking the bond between rubber and tarmac where otherwise more = better. Obviously wider tyres and steering is a trade-off. I remember no power steering on my 205 GTI, and low speed parking effort.
Reactions: Damo H
HumanSteamroller
26
No, I think you'd get the 225s on the BBS SR wheels, but I figure that having a bit of extra rubber on an eight inch wide rim might aid kerb climbing ability, stop scuffing the wheels quite as quickly when the wife is driving etc. :)
