Finally I got time to leave my car at my mechanic, who tried to solve the following issues:
- Engine overheating while driving hard
- Some squeaking noise in the engine compartment when the AC was on
- Left rear brake caliper was not returning all the way
- Squeaking noise from underneath the car when going over some bumps
Ad.1.: The radiator fan was shot. As the OEM was over 540 €, I decided to go for non-original part. For half the price I got the radiator fan AND the AC fan, with bigger motors. They just fitted in the original place:
Ad.2.: All of the sudden a squeaking noise appeared from under the bonnet. After a few minutes, I figured out, that it has something to do with the AC, as the noise was only present, when the AC was running. This occurred only a couple of times, but I wanted it solved. I was afraid it might be the AC-compressor, but in the end it was only the accessory belt tensioner. So this got replaced (OEM) and so did the accessory belt.
Ad.3.: The left rear brake caliper got a bit stuck, so it needed replacement. I took non-original part, as the OEM was about 240€.
Ad.4.: Squeaking noise from under the car was coming from the shot ARB rubber bushes
Additionally this surface was grinded:
A couple of potential problems were found:
Rusty power steering line:
Some leak on AC system:
We'll have an eye on these and solve it when needed. Apart from this, I suspect, that passenger window mechanism will have to be replaced. Also the rear wiper mechanism, along with the Fabia wiper is ordered and waiting for me at the dealership. I need to solve this ASAP.
All rubber hoses were also inspected and are still ok.
For the next season I am gathering the parts for the 4 pot Brembo brakes upgrade, along with the cupra R spec rear brakes. My mechanic had some 4 pot Brembo calipers from an BMW e38 lying around, so he made a really good offer and I went for it. It's going to be a long wait till march.
Anything I should be careful about, when upgrading the brakes? I don't know which discs (make) I will be taking (323mm I guess), aiming for ferodo DS2500 pads, braided brake lines and Motul 600 brake fluid. Any suggestions or comments regarding these parts?
