jambondrums
G'day!! Does anyone know if a set of 18x8.5 inch rial daytona race wheels wil clear the front brembos on an lcr? Cheers for the help in advance guys!!:D
As far as i can see no without spacers mate.
LCR wheels spces 18x7.5 ET38
Rail Daytona race specs 18x8.5 ET30
Going off this wheel offset calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
it will mean that the inner clearance will be -5mm but will also stick out a further 21mm from the origional position, so if you add say 8mm spacers to that to clear brakes it will mean the wheels will stick out nearly 3 cm's from the origional position so may look odd and not sure if it can fail m.o.t if the wheels sticks out too far from the arches.
Hope this helps mate and im sure someone will correct me if im wrong :)
i had them on my leon cupra ,they sat just pass the front arches by a few mm , i think you will need to get min. 5mm to 10mm spacers to clean the brakes , but by doing this the wheels could stick out by the arch about half an inch if 10mm spacers are used
Cheers guys!! Thanks for the info!! Sounds like they may well have some fitment probs then, seem to find this with quite a few wheels fitting over the front calipers!! Oh well, back to the drwing board!! Thanks again!!
