OK- I've plotted these results onto graphs and it seems that these values must be recorded with normal atmospheric pressure included at 14.696 PSI
The first graph shows the raw values logged by block 115 in PSI, the second is offset by 14.696 PSI to show actual boost provided by the turbo
Legend
Red = Requested boost
Green = Actual boost
From these results it looks as though everything is pretty much spot on, to me at least?
I think I may therefore need to take a look at the way in which my boost gauge is plumbed in as I'm only ever seeing 17PSI max and normal driving off boost it sits at -10. I've sleeved the provided nylon vac line into some 4mm silicone hose which then sits on the green nipple (also using a no-buzz t piece) but I've found
http://www.scoobymods.com/forums/showthread.php?threadid=210 which suggests another way of setting this up.
Anyone else had any trouble with Autometer mechanical gauges?
