Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
A W16W is the correct fitting, but if the reverse light is monitored by CANbus then you need a CANbus bulb or it will more than likely throw an error message.
Would this be a UK MOT failure same as replacing a headlight with a non-E marked aftermarket bulb? (assuming the tester is following the regs to the letter)
