Reverse light fuse location?
al.edm
MK2 Junky
Aug 5, 2014
20
Hey folks,
Can anyone help me out with findings the reverse light fuse? I think that I have mine blown.
Any suggestions?
Al
HasF
113
Reverse lamps are powered from the onboard control unit. You would have a fair few other things out also if this is the case.
Should be Fuse 17. Have you checked if there is power getting to the bulb side?
17 - Fuse 17 - 5 A
- Interior monitoring sensor -G273- 30a
- Alarm horn -H12-
- Dual tone horn relay -J4-
- Onboard supply control unit -J519-
al.edm
MK2 Junky
Aug 5, 2014
20
17 - Fuse 17 - 5 A
- Alarm horn -H12-
Hey thanks for the quick response,
The bulb is brand new, I also checked with another bulb - same result.
I do however hear a sort of a 'click' when engaging reverse gear, didn't hear that before..
Any conclusions?
HasF
113
I would firstly check if there is power getting to the lamp properly.
Use a multimeter and check the terminals.
Even better would be the harness going to the lamp. The reverse wire should be Grey/White.
Also try and locate where the clicking is coming from, you dont need to fully engage reverse to try this.
You could have a faulty Reversing Light Switch.
But i would ensure that there is deff no power coming to the lamp before proceeding anywhere really.
Mar 13, 2020
I getting a massage on my screen saying check the left hand reversing lamp i i ecked it and replaced it but sti not working i i check and there seems to be no voltage at the buld the other lamps are working on that side can u help why do car makers not label the fuse boards it's make think it make it easier to find where a fuse is
