Reverse camera to MMI
camboblanco
21
Afternoon all... I've purchased a reverse camera that replaces the registration plate light. I'm confident in fitting and coding, but unsure about the wires that goes to the MMI from the camera. The camera comes with the standard video cable but I'm under the impression that it needs to be converted in some way to fit into the blue connector on the quad lock. Does anyone know if there is a converter for such a thing or do I need to somehow convert the cable?
Antera
305
117
Breda, Netherlands
Www.vcds-coding.nl
Blue connector mediaunit pin 6 and 12
Red for 12v + in mediaunit or fusebox
And 1 wire on reverse light
If high line canbus lines on Grey connector in mediaunit
Then coding RVC in PDC and in Medianunit
Lock car dor 1 minute get in the car en it works.
José Silva
233
43
Portugal
