Restrictions in Boost Gauge Tubing
Mar 8, 2007
831
Hello all.
Can anyone tell me what to use as a restriction for my boost gauge tubing as its buzzing.
I currently have a nut and bolt between two ring connectors tighened over the tubing just behind the gauge and it has reduced the noise but not eliminated it completely.
Ive tried a hair pin in the tubing (doesnt work) and blue tack with a pin ***** through it (doest work)
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Ok. Mine came with a inline reducer. You could always use one of those 'T' pieces and blank off the other port.
brad1
what boost gauge do you have, and what is the buzzing sound, when does it sound?
Mar 8, 2007
831
Or don`t buy cheap shite and get a well made gauge next time either mechanical or better still electric microprocessor controlled gauge like an SPA.
Hi there mikeyboy. You are right looking back I should have gone for an electronic gauge however they are £100+, don't match my Skoda Green dash lights and I've already drilled the intercooler pipes.
I looked at VDO gauges and Blitz etc but they were just too expensive at £75-£150, and from several articles I've read they arent any more accurate and still suffer from the rattle.
The swoosh one seems to be reading fairly accuratly considering it cost only £32 (peaks at 20-21psi in 3rd gear, holds at 19-20 then drops to around 16 psi at the redline).
Damoegan
Oct 15, 2007
8,993
Newcastle
I have an electric boost gauge and it wasn't very dear. clicky
Mar 8, 2007
831
I physically needed green though as I've got a Slowda Fartbia aRSe
I've sorted it temporarily, I've got a 3mm hose connector shoved it full of bluetac and poked a sewing needle through it, no more buzzing!
I've contacted Awesome about an inline restrictor just waiting to hear back from them - should sort the problem for good.
Jul 23, 2008
720
Manchester - UNITED
I just got a short length of the silicone vacum hose, slit it down one side and put it over the hose. Clamped it tight at both ends with a little cable tie and it works just fine and can be tightened in little bits until it works ;)
