Resetting 5" infotainment system to factory settings via VCDS
Seif El Din
22
Hello, my infotainment is going crazy at the moment.. it greyed out date and time options from the settings menu, the bluetooth mic is not functioning and the ESC option says "Function not available".. and the list goes on.. so i was wondering does anyone have the original factory settings to be able to reset it?
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Have you tried resetting it by pushing the volume knob in for 10 seconds?
Seif El Din
22
Yes I did try that.. but no luck.. would disconnecting the car battery for 20 mins reset everything in the car?
Seif El Din
22
Yes, I was trying to code the new OPS, but ended up with a busted 5F infotainment system with several functions now unavailable... A long code would be helpful I guess ..
concerned cat
497
Huddersfield UK
My MO when playing with VCDS is to NEVER alter something you can't br totally confident with or change back. Simple really.
