***Replacing ko3 advice/tips/shorcuts***
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Yes heat sheild off, tip off, amount of money spent on new rachet could have got garage to it for dat price. lol
Even with spanner it keeps hitting something.
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
have you taken off mani? have you undone the bracket that hold the turbo on?
i did mine with spanner and wrachet socket when all this was taken off and water and oil lines disconnected so there is movement for the turbo..
Big_daddy
Oct 20, 2006
3,930
Brummy
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Ibiza 125: is this type of spanner you have used?
http://www.halfords.com/webapp/wcs/...uctId_214950_langId_-1_categoryId_165469#dtab
The mani is still on but ive loose all 3nuts that hold the turbo, where is the water lines? i cant seem em :confused:
one of the water lines is on top off the turbo (under mani) also there is a oil line there too, the other is on the back off the turbo by the block...real bitch to get to and the 2nd oil line is on the bottom off the turbo.
Big_daddy
Oct 20, 2006
3,930
Brummy
Cool cheers mat, give it another shot 2morow;), The main issue is getting the down pipe off, :banghead:
Big_daddy
Oct 20, 2006
3,930
Brummy
Ratchet with a swivel head is ideal for the downpipe bolts. I picked one up for a bout £4 and it's ideal, about 4" long, fits in your hand perfectly and just bend the head and you can have your hand and ratchet it anyway you want.
Also, IIRC you can one of the coolant lines off at the block rather than the turbo. Much easier access.
Ive using that (payed 22 dolla from halfrauds - guna return when im done :D ). Thing is abit awould in that location, better use plenty of wd40
Big_daddy
Oct 20, 2006
3,930
Brummy
Manged to get it off :funk::happy:
Used some S spanners- steady pace the exhuast came, follwed by mani, oil lines/water lines.
Just waiting for parts from seat arrive |(2working days:rolleyes: ). Lost all my coolant, how many litre will i need? (do full service since i drained d oil too.)
My exhuast manifold is quite dirty with gunk, around 1-2mm, shall i give it a clean or it wont make much different?
Supurb well done bud! Not sure how many litres but coolant comes as concentrate anyway ;)
Porbably no harm in giving it a clean. Cleaner it is the more flowing it will be!
Yeah I'm awaiting more parts as well as I need more new crush washers as it's leaking... I would advice you to do up the lines TIGHT!!
Big_daddy
Oct 20, 2006
3,930
Brummy
Cool, think it comes in 4litre i asume, at same time, some carb/degreser for the mani. plus need send new turbo get studs in as one is snapped and 3, look abit week.
Yeh will do, dont have energy to remove it again :(
Big_daddy
Oct 20, 2006
3,930
Brummy
Glad you've got it all stripped.
whats the reason you replacing the turbo or removing it?
Turbo seals starting to go, (change em now be fore its too late), The exhaust side looks ok may investigate it more and send it of hybridgnosing soon.
Big_daddy
Oct 20, 2006
3,930
Brummy
Just a quick question, plugging back the vacum lines, forgot where one pipes goes.
Its the one from the actuator lead to something (not from n75)? does it T peice into something?
Big_daddy
Oct 20, 2006
3,930
Brummy
Any know how long would it take for the smoke to clear out, roughly how many miles? Just got replacement fitted but still smoking?
