Moet, what engine do you have?
It is true, I replaced mine recently however I have the VE (110hp) diesel and my AC pump is located at the bottom of the engine so I could access mine from under the car very easily.
For mine, I did the following:
1 - Remove engine tray
2 - Remove the Auxillary Drive Belt (alternator belt)
3 - Remove the two pipes on the back of the pump (BE CAREFUL HERE, although kwikfit emptied my system there was still a little bit left and the pipe exploded off the pump, luckily my face was not near as it would have really hurt. Just make sure you keep body parts away and wear gloves)
4 - Remove the two 16mm bolts from the AC pump and extract them.
5 - Use the leverage of a screwdriver to assist in removing the pump.
REFITTING is the opposite however Firstly, you need to look at the new pump. Where the bolts go, there is a nut located in the pump already, it is round. You need to re-seat that nut. I did this by inserting the bolt most of the way, then stand the pump on its end and put a socket over the nut (slightly bigger as you are just supporting the pump with this. Next, use a hammer to hit the head of the bolt so that the nut is pressed into the housing. This explaination is a little confusing, if you need more
help let me know.
It is not that difficult, just be careful as it can be dangerous especially when taking off the AUX belt and taking off the AC pipes.
