Removing this' Sun Visor bit!
paul26982
As title how do you remove this, the other side that holds the Sun Visor, dont want to break it thats all
chappers
is it not just clipped in or screwed to the roof lining? i had to change the bulb in one of the interior lights in my leon before and that was just clipped in (used a flat head screwdriver to get it out).
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
there is two screws under that plastic cover. you need to prise it off with a small flat screwdriver very carefully. i broke one of mine doing it. they are only a quid or something off a dealer if you do break it. i glued mine back together.
the mirror twists off the base. not 100% which way is off but i think its counter clockwise. be gentle. its very easy to crack the screen
