- Firstly disconnect the battery.
- Then locate the two holes at the back of the steering wheel which house the securing clips for the airbag.
- Once you find the holes, insert at stubby screwdriver or something to undo the clips.
- Once the airbag is released unclip the wire that connects it.
- Then there should be one main bolt that secures the steering wheel to the column. Undo that and the wheel should come off.
