Removing Metal Disc Guard
Jan 3, 2014
593
Is there a way to remove the guard behind the rear discs?
Mines is rattling and it's doing my box it.
Sent from my SM-N9005 using Tapatalk
Jan 3, 2014
593
Can you not just secure it somehow
That's what I've been doing. but it only stays secure for so long. I'm just using small blocks of wood to wedge it in place. Going to do that again to night. But make it a bit more secure. Hopefully get it fixed for good later on when I have more time
MJ
5,555
35
Manchester
They are prone to corrosion and break away from the mounts. Wedging it will have to suffice for now until you can strip and remove/replace them.
Jan 3, 2014
593
strip as in remove disc?
Jan 3, 2014
593
Damn. Oh well. Wedge it till I get to the workshop haha
CupraVAG
30
North Scotland
Hey buddy. Had similar problem with my 2008 FR. Removed wheel, and disc. However, it's likely you'll need to remove hub, or cut dust plate out. I ended up using large washers to hold in place...
Jan 3, 2014
593
That's what I was thinking of doing mate. but need to know how to take disc off?
MJ
5,555
35
Manchester
Remove the wheel, remove the caliper, remove the t30 then remove the disc. There's enough room with the carrier left in place.
CupraVAG
30
North Scotland
As MJ has detailed, but if it's anything like mine, an hour of encouragement with leather mallet was required to dislodge the brake disc from hub after all components disconnected.
