paul26982
took 2 torque screws out and now want to disconect lead, pulled the head unit out and have plugged in at the back, black brown and blue plugs, is any of them it if not were is it at or how do i do it cheers lads
just stuck on the casing inside now, what the multi changer was in, any ideas
To remove the glovebox mounted 6 disc changer:
Remove the black surround
Undo the 2 Torx Screws
Pull the changer out and disconnect the wiring loom from the rear.
Unplug the blue mini ISO connector from the rear of the cars headunit and pull the wiring loom out through the glovebox.
To fill the hole left in the glovebox you will need a glovebox lining. I have one for sale (PM me for info)
or
You can go to SEAT and tell them part number 1M08686591UQ to get the glovebox lining.
how much m8, so how does the casing around the changer come out (the box what you left with wat devides the clove box)
@ArosaRacer
A up matey :D Not bad cheers. Been quite busy over the last couple of weeks mate. Good to hear your still around :D
At Paul26982.
The glovebox liner just slots into the space where the disc changer was and is about the same size as the changer. You also use the same torx screws for fitting.
Your glovebox has a small pocket to the right and a long pocket where the changer used to be.
