Removing CD Player?
  • Thread starter Deleted member 49775
  • Start date
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Personally I don't think you need the removal keys, I just cut up an old credit card. Worked a treat :)
ryan86
sterio wont power up with ignition?? why?
hi
i have an ibiza cupra tdi with an alana sterio, just recently got the car, the sterio will only power up if i press the power button on the left, then i need to turn the sterio off every time. this may be normal but im a newby, i just thought the sterio would power up with the ignition.
any one able to help?
DEAN0
Old Git
Feb 1, 2006
5,360
348
Preston - UK
hi
Sounds like the last owner might have had an aftermarket stereo in and swapped the two live wires over.
Does it keep the radio stations when switched off ?
I think there is also a setting in the menu for ign on/off control
attila_tdi
384
Hampshire
Sorry for the poor quality, low level light with a Iphone 3g aint its best area :ban:! You get the idea though!
Removing Tray
Tray removed
Removing head unit
Headunit out (Be careful of ariel cable on back right hand side of unit, will pop off)
Blue connector for AUX, (the one from ebay) green wire is touching pin 14
Pin 14 & green wire
Screen display when you have done it correctly
Aux & display
Hope these help
Jack
Please don't shoot me if this is covered before but do i still get cd player function if I do this mod?
