Removing Badges
FR*Man1984
time for a MINI adventure
I've had a look in the MK4 threads, and can't find what I"m looking for...so
I want to remove the TDI badges on either side of my car, and I don't seem to be able to do it without leaving the adhesive tape behind. Is there a way to remove them?...:blink: just to note, I don't have a hair-dryer as I know these sometimes helps. Unless I can borrow one from a mate... :doh:
gazjones
the adhesive should peel off if you can get under it! just peel it off slow and should come off in one bit
DanDiesel
In my diesel is where I'll be, chugging merrily.
Mar 17, 2005
168
10
Kent
hairdryer and then dental floss in a see sawing motion has done the trick on mine!!
EdButler
713
Sheffield
Hot water from a kettle is perfect using your nails - CREDIT CARDS LEAVE SCRATCHES (well they did on my old car!!) and some sticky stuff remover to get rid of the residual goop. If no sticky stuff remover, just use a little bit of T-Cut, Polish or Bug and Tar Remover.
