FR*Man1984
time for a MINI adventure
I've had a look in the MK4 threads, and can't find what I"m looking for...so
I want to remove the TDI badges on either side of my car, and I don't seem to be able to do it without leaving the adhesive tape behind. Is there a way to remove them?...:blink: just to note, I don't have a hair-dryer as I know these sometimes helps. Unless I can borrow one from a mate... :doh:
the adhesive should peel off if you can get under it! just peel it off slow and should come off in one bit
hairdryer and then dental floss in a see sawing motion has done the trick on mine!!
Hot water from a kettle is perfect using your nails - CREDIT CARDS LEAVE SCRATCHES (well they did on my old car!!) and some sticky stuff remover to get rid of the residual goop. If no sticky stuff remover, just use a little bit of T-Cut, Polish or Bug and Tar Remover.
