has anyone had problems with there key? the key works well the light flashes red when you press the buttons but it dont lock or unlock. Anybody got any suggestions
yep...sit in your car and close the door. then follow the steps below.:
1) put key in ignition
2) twist so that the ignition is turned on (dont start the car)
3) turn the ignition straight off and remove the key
4) within 2 seconds hold the lock button and press the unlock button 3 times (while still holding down the lock button)
5) the car will sit for a few seconds then lock and unlock itself.
get out the car, close the door walk away job done![]()
I was unable to get out of the car and my dad had to get the spare key from upstairs to let me out! i couldn't wind the window down to use the outside handle and the unlock buttons wouldn't work on the door!
